V Gilden
10 points
Posted on - 08/19/2016
My computer has encountered a type of virus or error that has completely hijacked my device and web browser preventing me from anything at all. I think it’s an Antivirus Live virus, please tell me how to remove malware manually?
H3nry
How to remove malware manually: Antivirus Live?
It is a very vicious piece of malware that can completely destroy your system. You cannot remove it by normal means or using any other antivirus tool. So, here I am describing the only solution to get rid from that:
ï‚· Press the F8 key continuously while Restarting your computer.
ï‚· Select the Safe Mode with Networking under the Advanced Startup menu.
ï‚· Now, you have to readjust your LAN settings. To do this:
 Open Internet Explorer > Tools > Internet Options.Â
 Go to the Connections tab, and then click on the LAN settings button.
 Uncheck the proxy server option, and click OK.
ï‚· Install the Process Explore from the Microsoft TechNet website and rename the downloaded file to explorer.com.
ï‚· Use the installed software to end the Antivirus Live Program.
ï‚· Delete the application folders and also remove the Antivirus Live Registry Entries.
ï‚· Reboot your computer normally.
