Hi guys,
I want to know how to remove Malware from my PC? I think m PC is infected with Malware. I use Microsoft Security Essentials and when canned PC I received a malware threat report and Microoft Security Essentials removed it, when I clicked on remove threat. But the problem is still my PC is infected and its running too slow. Please help me.
points
How to remove Malware from my PC? Please help
There are many good security software that provides more security than Microsoft Security Essentials. MSE isn’t as powerful as Microsoft isn’t 100% devoted to develop security software. They have to develop Windows, Xbox, Visual Studio etc. and much more.
I recommend to use Norton, Kaspersky, Avira, AVG, BitDefender etc. They are quite good in their field and powerful enough to remove any threat from your PC.
If you think the nasty virus program’s still on your PC, you should use any aggressive program that will remove the virus forcedly. You can use Norton Power Eraser, Malwarebytes Anti-Rootkit, Bitdefender Rootkit Remover etc. They are some aggressive soldier to kill tough viruses.
