How to remove MS Removal Tool ?
Posted on - 08/03/2011
Recently, I think my computer was infected by a virus called MS removal tool.What it does is it runs like it's looking for spyware/malware/virus and comes up shows that it has found a ton of them. When you ask to remove it, it charges you 49.99 (regulars) and 69.99 (premiums) for the software. I cannot scan the computer (I have Symantec Norton)and 80% of the programs doesn't work anymore. Please if you have a solution, tell me how to remove it?
