How to remove noise from an mp4 file ?
Hi, I have MP4 files that contain a lot of noise, it is possible to remove these parasites?, and I wonder if there is a noise removal tool in mp4?
Thank you!
Thank you!
You can open the file in different software’s like gold Wave and MP3 which are among the best formats and extract the audio file.
You can then change the threshold of the audio a little higher so that the lower frequencies are deleted or go to the ‘Effects’ and select the ‘Noise remover’ and your problem will be solved. Visit this site for more information.
Hello Emerson Hahn,
When you have unwanted sounds with your stream, try to extract your file with any Sounds Filtering software, and reduce the frequencies of the unwanted sound, try RemoveGain, it's a very powerful tool for sounds filtering.
Check also this video to know how to fix the frequencies, it may help you with removing background noise.
