Bryan James
30 points
Posted on - 10/13/2012
Hello Experts,
How to remove or disable windows 7 sound alert time? There are times that it can be so annoying for the computer user if this feature is enabled. Give me some ways on how to turn it off and get rid of it. I hope you can give me a step by step instruction regarding this matter.
Thank you.
Dana Cua
5 points
Hi. You can remove the sound by doing the following:
1. Right click on the empty area of your window. A drop-down menu will appear.
2. Choose Personalize.
3. A new window will appear and in that window, scroll down and click Sounds.
4. Select No Sounds from the Sound Scheme options and click Ok.
5. Test the settings.
6. All the alert sounds will be disabled by then.
Thank you.
Hi Bryan James,
I have attached a link below for your reference on how to disable or enable the sound alert time on windows 7.
Windows 7: Sound is Disabled or Enabled
You can also go to some forums for sharing or gathering some information so that you can know the best solution with your problem.
I have also attached a link of a good forum below:
How to turn off visual sound notifications
Hope that it would help you a lot.
Thanks and more powers.
There is a simple and easy way to do this, just go to control panel, there will be an option of Hardware or Sound devices. Select that option, on the top there will be a bar on that there is a sound option. Select that, andthere will be a bar, just select no sound from there and press OK. You will get rid of all the sound that you don’t want on your Windows.
