How to remove PC guard 2011 completely from Windows 7?
I have windows 7 installed and also have PC guard 2011.
I want to remove PC guard 2011 completely from OS.
Can anybody tell me how to do so?
Any kind of help would be appreciated.
You can remove the tool by following the procedure.
First open the control panel from start menu.
Then open programs and features which is the way to uninstall from your system.
Once you open the programs and features you will be seeing a list of applications that are installed in your system. First choose the application that you want to uninstall and then click uninstall button that you see above the list. This will uninstall the tool from your system.
If you were unable to do this way. Then locate the tool where you have installed then delete that folder completely and reboot the system this will clean your system completely.
Hello Eliza,
The following procedure should help you to remove PC Guard completely from your computer:
Hope this helps.
Carl
