How to remove PDF blank pages page break.
Hello experts,
There are some blank pages in between two PDF pages. I want to remove them. Do you know how to remove PDF blank page’s page break. If you know please help me.
Hello experts,
Hello Cooper, The easiest way to remove the pages is by making another new document using the Merge tool which is already available in Adobe Reader. Insert the pages you need in the new document and save it.
The second solution is to use the Adobe Acrobat if you have it installed in your computer, open Adobe Acrobat > open the document you wish to delete pages, go to the “documents” menu and select “Delete pages” then enter the page range you wish to delete in the provided spaces. Press OK. There is also a free tool online, the PDFMate which does the same. Hope this will help you.
Hi there,
It's really simple to remove pages from a PDF file using Adobe Acrobat. All you have to do is to follow the steps below-
1. Open Adobe Acrobat and open your desired file.
2. Go to "documents menu" and select "delete pages".
3. Enter the page range in the boxes.
4. To delete a single page just enter the page number in both boxes.
Thank you.
