How to remove PDF complete from Mac?
Hello experts,
How to remove pdf complete from mac? I want to make this happen for some reasons that the computer is having a problem and needs to be reformatted soon. I need you advise about this experts.
Thank you
Best Answer by Pike Hayt
Answered By 5 points N/A #147615
Hello Dibri Avery,
To remove pdf complete from mac you have to take several steps.
You have to find the application folder. See there is an uninstaller and run it.
If you don’t find the uninstaller download fresh copy.
Look there and uninstall the software.
Alert it will be difficult to remove for many rickety programs.
Answered By 0 points N/A #147616
Hi Dibri Avery,
If you want to solved this problem. If you have windows set up. Then you give windows set up. If you don,t have windows you can Google search then download and then the computer windows set up.
You try this solution.
I remind that is your perfect solution.
Answered By 0 points N/A #147617
Hello Dibri,
To remove the PDF for Mac, please follow the instructions below:
1. Open the "Finder" application.
2. Go the "Applications" folder.
3. Drag the PDF for Mac application file into the trash.
4. Click the "Go" menu from the menu bar.
5. Select"Go to Folder…" option
6. Enter the following into the "Go to the folder:" field:~/Library
7. Click the "Go" button again.
8. Click the "Application Support" folder.
9. Drag the PDF folder into the trash.
10. Now by clicking on the "Back" button from these Finder window go through the "Library" folder.
11. Select the "Preferences" folder.
12. Select the "Finder" menu from the menu bar
13. Select "Empty Trash Option"
14. PDF for Mac will now be successfully uninstalled.
Please follow the instructions that how to delete a PDF from OSX 10.5.4 from this URl.
Pike Hayt
Answered By 60 points N/A #147618
All of your remedies are terrific and thank you for helping me. Pike Hayt, for my problem, the solutions that I have searched on many sites are difficult and I am not capable to do their complex processes. I was very worried about this problem so I have come to techyv.com for the solution.
At last, I have found it. Reading your solution on techyv.com and applying it was an easy process. I am capable of removing PDF Complete from Mac. Thanks to techyv.com and also to my friend, for helping me.
