How to remove PDF margins with PDF remove margin reader?
How to remove or change pdf margins on an adobe pdf using pdf remove margin reader quickly to remove the margins?
Riyazi, here are a few simple steps to do this:
1. Open the PDF document in Adobe Reader.
2. Click "file" on the main menu bar and choose "print".
3. Open the drop down menu next to "print scaling" and choose "none".
4. Click OK.
Now you're done. Thanks and have a great day.
Another solution of adjusting the margin is to print the PDF to a new PDF with a shrink by a % set. With this approach your links will be removed but you will get the desired margins I think. This can be done while printing the pdf click on the shrink tab & select your % & done.
