How to remove PowerPoint protection
Hi everyone. I'm having a dilemma in my PowerPoint because I accidentally put a password, I need to know how to unlock or remove PowerPoint protection? Thanks for the help.
Hi Susan Rozack
I recommend you get yourself PowerPoint Unlocker that can modify instantly and securely removes any password. This application will enable you to reuse your slides, pictures and other elements within minutes after editing your new password. Hope that was easy right, instead of re-creating the presentation once more again. All the best Rozack.
There are many tools available in which you can use to recover the password on your PowerPoint file. You can try any of the tools below. Just click on the link to download the software:
1. PowerPoint Password Recovery:
http://lastbit.com/powerpoint/default.asp
2. PowerPoint Key
https://www.passware.com/kit-basic/
3.Office Password Unlocker
https://passwordunlocker.com/office-password-recovery.html
Hello Susan Rozack,
Remove or delete the password from a PowerPoint presentation is not a difficult thing to do. As you have not mentioned which version of power point you are using so I'm giving you an idea of where you can delete the password because there isn’t much difference between the different versions of PowerPoint. Now go to the office button then click save as and select the PowerPoint presentation. From the save as dialog box click the Tools after that from the menu select the general options. Then a new dialog box will appear there you will find the delete or remove password option, choose between open, modify or both. At last hit on Ok to save the presentation to a new file or the original.
Thank you.
Hi Susan,
There are various possible solutions to your dilemma. You can unlock a password protected PowerPoint file by the following:
Hope this aids you in resolving your PowerPoint problem.
