How to remove “Publisher Not Specified Error” message
I am getting Publisher not specified error as I try to run Adobe PDF document from a CD.
Please help me to remove this option.
The autorun. information is given below.
You actually get this error (publisher not specified error) if you try to launch pdf directly without specifying the application executable.
This is because the autorin.inf only shows signed application publishers like Adobe if you specify the said application executable.
Here is what we can do in this case:
You would have to copy a number of files directly from the CD that you are using. They will exes, dlls and other adobe reader related files. You would also have to change it to Acrobat reader program instead of pdf. Have shellexec launch adobe reader on the options to launch file.
