How to remove “recycler” from computer?
How do you remove "recycler", from the computer?
There could already be more substantial damage to your computer than you realize. The "recycler" virus, is caused by removable devices such as iPods, pen drives, flash drives, etc. It utilizes the autorun feature in Windows, to jump onto your hard drive. It will allow others to steal personal information. So please, be careful what you are accessing on this computer, until you have time to resolve the issue.
Most damage takes place in key system components, like your registry files. It is a time consuming process to repair this on your own, but it can be done. Microsoft has included tools within Windows that will allow you to successfully remove this virus. You need to also determine what device has caused the issue and remove the virus, so that it does not continue to execute itself over and over again. This virus causes your computer to relay strange error messages, as well as restarting itself shortly after startup. Here are a few methods, that are proven to work, to safely remove this virus from your computer.
This method allows you to use the tools that are included in Windows, to safely remove the virus. You must restart your computer in safe mode, to complete these steps.
Plug all your external devices in first, if you do not have the USB ports or a hub to support this at one time, repeat the steps until you have completed the steps with all devices that could be affected.
You can also remove this virus using other free, as well as paid programs. The steps are very similar to the ones listed above.
This is the manual method, it does work but be careful. If you remove/modify a wrong entry, you can cause severe damage to your system.
The virus should be removed from your computer. I really do caution you against using this method, unless you have some advanced skills with Windows. The damage that can be created if there is a significant error made in a registry file can render you computer completely useless.
If these steps do not resolve the problem, you maybe having more than one virus affecting your computer or the damage to the registry files may be more significant than expected. This is a very destructive virus.
It may require having the computer serviced professionally to repair the problem. I would also recommend completing a backup of your system, before you begin working on any of these solutions. You can never regret the decision to be cautious and take the extra time to create your backup. This will be extremely important in the event you need to have you computer serviced. Most service and repair centers are going to reformat the hard drive and reinstall the operating system. This will result in all of your data being lost.
Now after you were facing a Virus, it is the best solution that you format your USB by just right clicking on the USB folder and then click the "Format". It will format all data from your USB and it will be perfect. But now if this Virus is also copied in your system then you can "run" a full scan of Antivirus on your system.
Although with your project, what you can do is that just install RAR on your PC and put all your projects in that program for compression. It will also compress your data and it will not be virus affected. Once you've done it, you can copy it to your USB and then you will see that no data is lost. If the problem remains you can also update your Windows.
But in case, your USB is not going for a format then, you can just go to same program and then from RAR program, open your USB drive. Now see all the files and folders in your USB and click on the virus program and now click delete. This will delete the Antivirus and will work fine.
The same thing can also be done using DOS, if you know that you can also edit the virus file and can delete all data from that virus file.
OK that's it.
