How to Remove Saved Passwords from the Cache of the Computer?
I have accidentally saved password from an unwanted device for a particular confidential secured webpage. How can I remove it from the computer's cache? I am using Mozilla Firefox.
If you want to clear Mozilla Firefox password(s), then don't panic. You can follow the simple steps mentioned along.
While the Firefox browser is open, click on Tools. Select Options from the dropdown. From the Options window, select the Privacy tab and then tick the Clear button on the "Saved Passwords".
When running Google Chrome, simply press Ctrl + Shift + Del on your keyboard to launch the Clear browsing data window. Check mark the clear saved passwords checkbox and press the Clear browsing data button and all saved passwords will be removed from the cache of the machine.
