How to remove text on photo?
I recently want to delete text or some unwanted areas in the photo. I want it to be not noticeable and professional done. Any ideas anyone?
The most commonly used yet not so efficient for this is the Healing tool. Just click the object you want to delete and the surrounding pixels will just fill on it. However this also can be its own disadvantage, sometimes the result isn't what your looking for. I recommend using Clone tool as it accurately covers areas from the source you chose.
There is a new trick that is only found in adobe Photoshop CS5. So if you don't have one, don't bother reading this because it wont work on previous Photoshop.
So the first thing you would do is open your image then select the object you want to delete in any possible selection. Selection may include but not limited to magic wand, lasso tool or marquee tool. After you have done selecting your object, hit the delete key and there would be a window popup that will display the type of fill to use. Select the content-aware fill and press ok.
This would delete the object and Photoshop will automatically fill in pixels surrounding it making it like there was no object there before. Enjoy!
Unfortunately I don't have CS5, I've tried the first method and it is absolutely awesome! It is barely noticeable! Can you give me further additional solutions in how I can make this into more professionally done job? Thanks by the way.
There are many ways you can do this. One is using the marquee tool to select a piece of the picture you want it as your source. Copy it by pressing ctrl C and using your move tool, place it above the unwanted object. This only works if the picture is very simple and has no other object. This method isn't recommended for complex or detailed photos.
You could also try the marquee tool. Select a part of your photo you want it to be your source and place it on the text. This is very inefficient method.
Thanks a lot guys! I finished removing all of the text on my photos. The tip you gave did have a big influence to it. Hope I can return the favor to you!
