Hi everyone,
I scanned my windows PC for virus actually I set the schedule scanner to scan twice in a week with Microsoft security essentials and found trojan virus in it the scan results showed trojan virus and wen I click to remove the virus it is not deleting or removing virus from my PC.Though I don't use internet much very rare then what might be the reason I got trojan virus in to my PC.Please help me how to remove trojan virus is there anyway I can remove it.
How to remove trojan virus from my PC?Please help
It seems that you have been affected by a Kernel Trojan. You can try to solve it by using the following methods-
Scan in Safemode
Restart your PC
Before the windows logo comes up, Press F8
Choose safemode
Do a full scan using Microsoft Security Essential
Remove the Trojan
If the above system doesn't work, try using TDSSkiller.zip from Kaspersky.
Download TDSSkiller.zip
Unzip the download file.
Run the Extracted file (TDSSkiller.exe)
Click on Change Parameters and check the boxes under Additional Options.
Click Start Scan and wait for it to finish.
If it finds anything, click Continue to proceed with default actions.
Reboot if the software prompts you to do so.
