How to remove user level security free
I am using Access on my Windows XP. I have set the user level security on the database.
But Now I want to remove it. I am searching that what is the easiest way to remove user level security free.
Any suggestion and ideas are welcomed.
Best Answer by wagner regina
Answered By 0 points N/A #181490
To remove user level security free in Access you are required to follow these steps.
  • Open Microsoft Access.
  • Go to database that required to remove user-level security.
  • Log in as a administrator
  • Allow Users full permissions on all tables, queries, forms, reports, and macros in database.
Hopefully this information will help you.
Thanks
Tritt Rochelle
Answered By 5 points N/A #181491
Good day Eri
What you need to do, logon as workgroup administrator. Give the usergroup full permission on all levels. You exit and open the application again. Now you create a blank database and leave it open. Then you import all objects into the new database from the original one.
When users start using the current workgroup information file clear the Admin password. this will turn off the logon dialog box.
The new database is not secured
I Hope this will help you.
