chelseaN
Posted on - 02/02/2012
An error message has showed in my pc when I try to detect the virus.VBS.Small.a Error message is “No scenario file autorun.vbs found” I want to get rid of it.
Userinit Rez_SZ D:WINDOWSsystem32userinit .exe,
Help me.
How to remove .vbs files
NOTE: Remember to backup your system registry before modifying it in any way.
Open the system registry and look for the registry tree find and open the section [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionWinlogon]
Once there delete the record "Userinit"="userinit.exe"
Apart from the record "Userinit"="userinit.exe" the following record may also be present on your PC:
Do not delete this record as your OS will become inefficient. BE CAREFUL!
Once again in the registry tree find and open the section [HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerAdvanced]
Delete the record "ShowSuperHidden"=dword:00000001
Close the registry
Click on Start > Run > Enter explorer and click OK
In the partitions of the hard drive and all removable drives delete all files named autorun.*
Remove all files named autorun.* in the directory C:WindowsSystem32
Reboot your PC and that should do it.
I guess you get the computer virus name AUTO.I suggest you using anti-virus software to killing them. Recommend you use kaspersky or 360 software.
chelseaN
Wow, thank you for the solution RichalleRipan.I typed regedit in the command prompt and located in [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionWinlogon] and deleted "Userinit"="userinit.exe" .Then I located [HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerAdvanced] and deleted "ShowSuperHidden"=dword:00000001. Next, I followed your step to click run explorer.exe and clicked ok. I already deleted all the autorun files in C:WindowsSystem32. Thanks
