How to remove virtual drive from my computer?
Whenever I start my computer, it gives me an error message indicating that the files are missing. These files are ‘vnetsup.vxd’ and ‘dfs.vxd’. Please tell me what should I do
Hey Stephanie!
I also had the same problem. I searched on the internet to solve this problem. I done each and every thing which I could do to overcome this problem. But I found myself with no luck.
Anyways what I did was a simple trick. You just have to follow these steps to overcome the error.
1. You have to download the Vredir Dfs Vxd repair software.
I am going to add the link for the software.
www.pcmmc.com/download-repair?Vredir%20Vxd%20Dfs%20Vxd
2. Install the program and run it. Click on scan button. It will automatically fix the errors.
3. Now restart your PC.
You will not face this error anymore.
Alternatively you can also use "system restore" to avoid this problem.
Click on Start menu > Program Files > Accessories > System Tools > System restore.
It will restore your settings to previous restore point.
Hey,
If you are using any third party software to enable virtual drive, you can disable them through the same.
If you enabled virtual drive & uninstalled the third party software, then follow these steps
1.Goto start — settings–control panel–Administrative tools–computer management– disk management
2.Right click on offending virtual drive
3.Select properties
4.Under driver tab select uninstall the driver
5.Confirm uninstall
Thanks,,,,,,,,
