How To Remove Virus From PC – Steps To Follow.
There is an infection of virus on my computer. There is a security risk to my files and personal documents, and can have an impact on the performance. How to remove virus from PC?
Virus is the malware that replicates and infect the programs when we execute them or modify them. It also causes economic damage due to the system failure. We can remove them with the help of free and open source antivirus software.
Method 1- Doing it manually.
Step 1: Adjust Autoruns' options after donloading it.
Step 2: Select Filter Options after clicking Option.
Step 3: Reboot into Safe Mode with Networking.
Step 4: Start the Autoruns program.
Step 5: Search and delete the malware entries.
Step 6: Reboot the computer.
Method 2: Removing Mac viruses.
Step 1: Scan for viruses after installing antivirus program.
Step 2: Remove the Flashback virus after reinstalling OS X.
Step 3: Remove the FBI Mac OS X virus (MoneyPak).
