How to remove window task manager useless applications
Hello experts,
How to remove window task manager useless apps? I would like to end or remove some unwanted and not working applications in my windows task manager but I am afraid of making a move when I am not really sure what to do. That is why I need your help to guide me on the process.
Thank you.
Best Answer by JosePhillips
Answered By 0 points N/A #181265
Jayden,
Here's what you're going to do:
1. Open the windows task manager by pressing Ctrl-Alt-Delete, Ctrl-Shift-Esc or by right clicking on the taskbar and choosing the task manager option.
2. Click on the task you want to remove. Make sure that you will click only the unwanted apps you want to remove.
3. Then click the end task button. This will remove the task from the windows task manager and stop the application from running.
4. Close the task manager window.
Answered By 10 points N/A #181266
You need to make sure the programs you are closing aren't being used by other running programs; otherwise it can seriously mess up your computer. If the programs aren't responding, however, they need to be terminated.
1. Press CTRL + ALT + DEL.
2. Start task manager.
3. Any programs not running properly will say "Not Responding" next to them. End those programs.
If the same programs are continuously malfunctioning, try uninstalling and reinstalling them.
Answered By 60 points N/A #181267
Hi Jayden Horribol,
I have attached some links that would give you some tips or ideas on what would be the best way to pick the unwanted/not needed applications that is running in your Windows task manager:
