Hello Experts,
How to remove window task manager useless apps? There are some running processes in my computer which is I didn’t get some permission to allow it. Why is this happening is it possible for me to remove some running applications from my task manager? If there are some ways then how? I need your help.
Thank you.
What are these applications that you're saying, could you give examples? Well anyway disabling them is easy, just open your task manager, then in the Processes tab choose the application right click it then choose End process. But before you start disabling applications you have to be sure what these do to your computer because some are necessary to run your computer and if you disable them by mistake it may cause problems.
Hello Vanessa,
Some times its not possible to remove running processes because they are essential for the smooth running of the PC.
While task manager is useful, it can too technical for normal users. You should extremely careful in removing processes are stopping some may cause instability to your PC.
I would suggest using tools like System Explorer (see this post for details on installation and usage).
Its much simpler and allows more options to control and manage PC.
Hope the post on System Explorer helps.
Mclean Buono
