How to remove word on video?
Hello guys,
I just want to know on how to remove word on video? In some movies on what they called as subtitles is there a software or a way that we can automatically remove all the uploaded subtitles while watching some downloaded movies from the internet? I need to know.
Thank you.
Best Answer by Pastor Beb
Answered By 0 points N/A #187967
I recommend you to use StreamedMP Editor software.
With this software, you can eliminate the word in the video, as well as other items you do not want.
Answered By 0 points N/A #187970
Hello Stephen Heris!
There are many video editing software that allow you to remove text or logos appears on videos. I will suggest you CyberLink Power Director. You can blur subtitles using this software.
Answered By 590495 points N/A #328175
The “texts” or “words” that appear on movies and video clips are called “subtitles.” Subtitles are sometimes included on movies as a separate file and sometimes it is encoded directly to the video. If the subtitle is encoded directly to the video, there’s no way you can disable it from appearing in the video because it appears as part of the image or the video itself.
But if the subtitle is a separate file which is common when downloading videos via torrent, you can either rename the subtitle file or disable the subtitle in the media player you are using. Subtitle files use the “.sub” extension name. If you have this file with your video, you can change the extension name to something like “.su” so the media player won’t be able to read it.
Just restore the original extension name once you are done watching. Another way is to disable the subtitle option in your media player. Like for example, in VLC media player, go to “Tools” then “Preferences” or press Ctrl + P. In the preferences screen, go to “Subtitles / OSD” tab. Under “On Screen Display” section, uncheck “Enable On Screen Display (OSD).”
This disables the messages on the video. You can also uncheck “Enable subtitles” to completely disable the subtitle feature in VLC media player.
