Larry smith
60 points
Posted on - 08/05/2011
I have a worm, there is no doubt.I am saving my photos to Picasa/Google and plan to wipe the hard drive clean and reinstall windows 7.
Here are the question. Can I email to myself some documents(maybe 20) via yahoo mail and when i 'm back up running download them back?
Can or does the worm have a chance of reinfecting the computer  again!!!
How to remove worms in my computer?
Since you have recognized the specific project that is part of the malware, and you need to uproot it, satisfy take after the proposed strides. {Download and concentrate the Autoruns system by Sysinternals to C:Autoruns}. Reboot into Safe Mode so that the malware is not begun when you are doing these strides.
A large number of malware screen the keys that permit them to begin and if they acknowledge they have been uprooted, will programmed trade that startup key. For this explanation booting into safe mode permits us to get past that guard in most cases.
Pilot to the {C:Autoruns envelope you made in Step 1 and twofold-click on autoruns.exe.} When the project begins, click on the Options menu and empower the emulating alternatives by clicking on them.
This will put a checkmark following to every of these choices. {Incorporate discharge areas}{Verify Code Signatures}{Conceal Signed Microsoft Entries}.
Then press the F5 key on your console to revive the startups record utilizing these revamped settings.
Yes you can transfer the files to yahoo. But Yahoo accepts only a specific limit of attachment. You can transfer the files to Yahoo. But make sure when you format your computer you install an Antivirus and Worm detecting software that can help you protect your computer when you download those files back if they contain any worm or virus in those files.
Don’t forget to update the database of the Virus detecting program so that it can detect all virus even which are new one which get updated by the Software company who owns the program. Basically some of the famous and effective applications for virus removal and protection are Quick Heal, Avast , McAfee etc.
You can download these for free from this link below:-
http://download.cnet.com/windows/
