Hello experts,
Give me the best antivirus that can remove yontoo layers virus.
I am afraid that this virus may harm all the files that my local disk drives have.
And It is hard to recover all the information in the computer.
I am using windows 7 operating system and avira antivirus.
Need help.
How to remove yontoo layers virus?
It is possible to uninstall Yontoo layer from your system. Remove Yontoo Layer under Programs/Features, then open your browser and remove the PageRage add-on.
If that doesn't work, Download Malware Bytes and run a complete scan on your computer.
If that still doesn't work then your last resort will be to manually remove all the files associated with Yontoo.
Here are the files you need to remove:
*Press Shift+Del to permanently remove the files from your system
**Make sure the Show hidden folders is selected under folder options
C:Documents and SettingsAll UsersApplication DataTarma Installer{889DF117-14D1-44EE-9F31-C5FB5D47F68B}_Setup.dll
C:Documents and SettingsAll UsersApplication DataTarma Installer{889DF117-14D1-44EE-9F31-C5FB5D47F68B}Setup.dat
C:Documents and SettingsAll UsersApplication DataTarma Installer{889DF117-14D1-44EE-9F31-C5FB5D47F68B}Setup.exe
C:Documents and SettingsAll UsersApplication DataTarma Installer{889DF117-14D1-44EE-9F31-C5FB5D47F68B}Setup.ico
C:Documents and SettingsAll UsersApplication DataTempYontooTix2700750.log
C:Documents and SettingsAll UsersApplication DataYontoo LayersYontooIEClient.dll
C:Program FilesYontoo Layers
