kylokram25
Posted on - 08/03/2011
Hi! Everyone,
I badly need help regarding this "YourGame" thingy which always appears in my desktop every time I turn on my computer even though I deleted it before when I turn it off. I think it's a bug or something like that. Does anyone know how to "eradicate" this "YourGame" without formatting my computer?
Thanks a lot!
How to remove the YourGame icon in the desktop?
How about trying Malware bytes?
It's an anti malware that surely works.
Your computer might have got infected by a bug or spyware. Visit link to download it and install.
Anyway, have you installed a new game on your computer before you experienced this problem?
If that's the case, uninstall and reinstall that game. To do so go to,
Start > Settings > Control Panel > Add/Remove Programs (look for that game)/ UNINSTALL
Or you may try also changing the same way of opening your game.
Usually, we do it in a new window. But try to do this.
Start Button (right click it) > Go to Properties > Select Start Menu Tab > Then Customize button ( from 'Display as Menu' change it to 'Display as Link')
Hope it helps.
Ah! Now I get it. I installed Angry Birds and it started there.Thanks a lot Mr. Gilbert and Comtech_1439. I'll try that.
Thanks!
Hi!
Your question is good. But you did not mention that which operating system you are using and after play which game is first coming in your desktop. Basically, this icon is coming after it installs Angry Birds game under Windows 7 operating system. Now today’s many people are facing the same problem with the same game. Now please do below things and hope your problem will solve.
Please install PCFresher System Utilities tools.
After that use all of its utility and clean your junk and windows registry also.
Another way is download Malwarebytes and try to check your computer with this.
Hope you will get solution
