How to Remove Youtube “Video Unblocked Worldwide”?
Asked By 100 points N/A Posted on -
My problem is I'ved just uploaded my Video Copy from my CD i bought, it is a Full Movie I uploaded. So after I finished upload. Then there it is  the icon next to Video Filename is a red box written with exclamation mark in it. then followed with  a three word which is "Video Unblock WorldWide". cause it gives me bad status on my youtube account so i need to remove the video unblock worldwide. Guru's help….please…
Best Answer by Fosso pradha
Answered By 0 points N/A #82296
Dear User,
There should be a reason for you to get your video blocked.
Mostly because of a copyright material. So make sure you haven’t posted anything like that.
And if not you can dispute. Below is a video which describes how to do it.
if dispute doesn’t get accepted , you are going to have to remove the video in order to remove the blocked sign .
thank you.
Answered By 0 points N/A #82297
This is for the reason that the movie you bought is a copyrighted one. Which means, they do not allow copying of the content of the movie and they choose it to be blocked worldwide. Tips on unblocking the copyright materials are all over the internet. But if you are trying to upload it on YouTube, it will work for a day only because once YouTube finds out about it, they will remove your video without notice. And worst, they will remove your account once you repeatedly do it. I think the best way is to inverse it and change the sound a bit before you upload it. There are many software tools that you can use on editing a movie.
Please note also that copying of a copyrighted materials are illegal.
