How to rename the ddhg screenshot?
Hi Experts,
I have created a screenshot and its name is ddhg.I want to give a meaningful name to that. Does anyone know how to rename the ddhg screenshot. I created this screenshot using windows paint. Just provide me the exact steps to achieve this.
Thank you.
Best Regards,
Jaycepierce
Answered By 0 points N/A #131211
Hi Jaypierce,
There are 3 ways to solve your problem.
1.       Right click your snapshot and choose the rename option. After that you can give a name for that.
2.       Right click your snapshot and choose the properties option. Then you can give a name.
3.       Select your snapshot by right clicking once and pres F2 to rename.
By those 3 steps you can rename any files or folders.
