Hi Experts,
I am having a gif image and need to rename it.Tell me how to rename titanium display gif image.I am having this gif image in a folder.I want the exact steps to achieve this.Thanks.
Jermaineporterrr
How to rename titanium display gif image ?
I’m quite confused on what kind of file you want to rename. If it is just an ordinary file on your computer, you can rename it by simply right clicking on the file or image file then select Rename then just type the new name of the file. But if the file you are saying here is kind of a system file, I’m not sure if renaming it is such a good idea since this might cause error on your system because of a missing file.
Renaming of an image system file will result to a missing file because the system will no longer be able to access the file because it is already using a different name.
