How to render Photoshop elements from psd to html?
Hello experts,
How to render Photoshop elements from psd to html? Is there a possibility to render a psd or html file from a Photoshop application software? If there are some chances that it is possible, give me some details on how can it be done. I know you can help me.
Thank you.
Best Answer by Nicke Baker
Answered By 0 points N/A #182855
Hallo Shannon,
It is very possible to render adobe photoshop elements from psd or html file. Here is a procedure that will be of great help with that:
  • First, you will need to click "File," and then "Open." After that you will choose the photo you want to edit, then click "Open."
  • And then you will press "Ctrl" and "A" on your computer at the same time. Press "Ctrl" and "T."
  • And then hold down the "Shift" button, and then click on one corner of the image. While holding down the "Shift" button drag the corner of the image to a smaller border
  • After that  you will go to the "Crop" tool in the toolbox and then click and drag your mouse over the image, creating a crop box as small or smaller than the image.
  • Press "Enter” on your keyboard and then click "File," and then click "Save as” and save the file.
Nicke
Answered By 10 points N/A #182857
At first you need to know that HTML is a coding language.
If you want to convert the PSD to HTML then you can use the adobe Dreamweaver. It is actually a very good software for HTML coding. You can make any kind of change by using the adobe dream waver. I think now you can make any changes in that PSD file.
