How to Repair Absolute Database and Prevent File Corruption?
Some situations cause file corruptions and makes the system crash and I'd like to ask that if ever it does happen, how can you repair the absolute database?
Hey Joycedparker,
For this kind of situations when system crashes or files are corrupted, you can use some database repairing soft. They are easy to download, install, does not cost much and very effective. Using these softwares are more effective instead of finding the error manually. I have listed some of these softwares below –
1. Exact Way To Repair SQL Database – http://soft.udm4.com/Utilities/Exact_way_to_Repair_SQL_Database.html
2. Repair SQL Server 2005 Database – http://soft.udm4.com/Utilities/Repair_SQL_Server_2005_Database.html
3. SQL Database Repair Tool – http://soft.udm4.com/Utilities/SQL_Database_Repair_Tool.html
4. MDF Database Repair – http://soft.udm4.com/Utilities/MDF_Database_Repair.html
Hope this resolves your problem.
