How to Repair Broken Micromax Mobile X600 Touch Screen?
I broke the touch screen of my Micromax Mobile X600 Dual Sim. Everything seems to work fine. The touch screen is still responding, even the accelerometer still works. Where can I have the screen of my touch phone get repaired?
Thank you.
Best Answer by Faith Bandler
Answered By 0 points N/A #165572
Hello Nood,
The problem that you are facing is becoming a common issue among gadget users. What you have to do try to find out your nearest Micromax service customer care center.
From where you can easily replace the broken screen with a new one with minimum charge and if you fail to find any service center then take your phone in any phone servicing center.
Try to take the help of the internet (Google) regarding your geographical location try find out your nearest Micromax phone service center.
Answered By 0 points N/A #165573
Hello!
It's a usual issue. Please don't be upset. Try to search a reliable cell phone repaired showroom. It will cost very low because it's a small problem as your phone's screen is still alive.
If you have no idea about nearest location, you can call cell phone customer care or search by internet for getting the nearest location for repairing it. Hopefully, your problem will be solved very soon.
