adelica
Posted on - 09/17/2011
I'm having problems extracting the content (s) of the archive, due to volume corruption, due to CRC errors and many more.
" " . The volume is corrupt.
" ". The volume is corrupt.
" ". The file is corrupt.
ijpnet
5 points
How to repair Corrupted RAR Archives with Recovery Record
Hi Adelica!
Indeed, the RAR archives are corrupted and it needs repair. You may try to download and install the WinRAR 4.01 (32-bit).
Just follow the prompts and then restart the computer, so the change will take effect. If this solution will not fix the issue then try to perform, system restore. To restore to an earlier date when you did not encounter this issue:
Start/Programs/Accessories/System Tools/System Restore.
If the problem still persists, then try to perform the repair reinstall using the Windows CD.
lee hung
75 points
Re-download the corrupted parts. Check the archive in the WinRAR on Recovery Record. Check properties. To go there, right click properties; fix the archive by simply repairing the archive ; then re-download the corrupted part of the file and up loader to re-upload it.
After that, open any part of the file with the WinRAR and click the Up one Level Button and highlight the corrupted file. Now go to tools and choose the select repair archive and press alt+R, when the box pops up ; then select the corrupt archive in the RAR and click ok.
