How To Repair Microsoft Office By Using The Setup ISO?
The office that I have installed in my system is not opening and unfortunately stopping on its own. So I want to repair the application by using the setup ISO. How to repair Microsoft office?
To repair the office applications by using the setup ISO follow the steps
Step 1: Double click on the setup ISO to open the setup directory on Windows explorer.
Step 2: Now run the setup file by clicking on the setup.EXE and run the setup
Step 3: After some checking of files the repair button will be visible. Click on it.
Step 4: The process will take 20 – 60 minutes to complete
Step 5: Once the process is over click on the finish button.
If your problem is with the entire Microsoft Office suite and not with a particular Microsoft Office application like Microsoft Office Word, there is an option to repair the package and you can do it right within the Control Panel. Click “Start”, “Control Panel” then “Programs and Features”. If you don’t see this, set view to “Small icons”.
On the next screen, scroll down and locate Microsoft Office. Select it then click “Change” or right-click Microsoft Office then select “Change”. On the next screen, select “Repair” then click “Continue”.
Follow the succeeding instructions. Insert your Microsoft Office installation CD or DVD when you are prompted then continue. When setup prompts you to restart your computer, just restart the computer. If the problem continues, uninstall and reinstall the entire Microsoft Office suite.
