How to Repair mov Xvid From Crashes and Bad Frames?
Is there a software or tool that can help me fix or repair mov xvid files when it crashes and producing bad frames? I'm encounter a lot of bad frames while playing a mov xvid file now.
If you have a video that sometimes crashes or doesn’t play normally, try converting the video to a different format.
A video that sometimes suddenly freezes or becomes choppy is a result of an incompletely converted video. Check if the video you have is a converted version and has its original file. If the video has an original file then check if the original video is clean and doesn’t show any sign of sudden freezing and choppiness. If you find some discrepancies between the two then you just simply need to convert the original file to the format you are using right now.
If you want some handy video tools you might need in fixing your video’s problem, you may try visiting ImToo Software Studio.
