I Have Acer Laptop. Some Days I Am Following Laptop Cooling Fan Did Not Work Properly. Some Time Fan Running And After That It Is Off. When Cooling Fan Is Off It Is Very Hot.
When Laptop Is Hot I Can’t Work And It Burns My Pillow. Now How I Repair My Laptop Cooling Fan?
How to Repair Processor Cooling Fan?
To save on power, the fans of laptops are set to turn on and off at specified intervals depending on the temperature of the system. The "Some Time Fan Running And After That It Is Off." That you are referring to is probably the fan spinning to cool the system down then shutting off because the temperature has already reached the desired level.
My suggestion is to never place your laptop on soft, cloth surfaces (such as a mattress, pillow, thick tablecloth, etc). These surfaces block the ventilation holes located at the bottom and on the sides of your laptop.
When these are blocked, heat builds up faster. If left unchecked, it could lead to premature failure of your hardware. Make it a habit to work on a desk instead of on the bed. Consider buying yourself a laptop table.
Overheating is a great problem for one's laptop. If it heat much it can fry delicate circuitry and chips. So you need to keep cool your system to prevent damage. You can keep it cool by taking some process.
1. The first cause of laptop overheating are the computer components.
2. The poor ventilated environment. And direct sunlight.
3. Dust. Dust build up can insulate components compromise their ability to cooling off. The internal fans can manage a fair amount of dust.
To prevent from this problem you should keep your laptop a clear place which is not a dusty place. You should keep your laptop a clear place where sun light can not enter in your laptop and ventilated environment is well. You should not keep your laptop in towel or others.
HI there,
Heat are indeed the cause of shutting down your laptop automatically. And this situation thus can make you work delayed at any time. Cooling thus are very helpful to its hardware and needs to have sufficient amount of cooling effect.
In order to make it cool enough, you need to have a cooling fan that has a BIG FAN that can be put below your laptop. This image is a COOLING FAN that is suitable for any laptops.
Actually this can be found in any computer store in your area. I recommend to call for a technician to repair your COOLER FAN.
IF the cooler fan you meant is a BUILT-IN, the don't try to fix it. Just BUY a COOLING FAN stated above. Because fixing and opening the laptop can cost same as buying a new one.
I hope that this will help you solute the problem.
This problem is normal with laptops. When using your laptop, avoid placing it on top of a pillow because it will only cause more heat. You should place your laptop on a flat surface so there will be proper ventilation underneath. To work around your problem, you can use a cooling pad for your machine.
Try checking out Laptop Cooling Pad 2 Fan USB Powered on eBay. This is for 14-inch to 17-inch size laptops. It costs $15.29 with free shipping worldwide. See exclusions to check if your country is included for free shipping. Also check Mini Vacuum Air Extracting USB Cooling. It is a vacuum-like device you attach on the side of your laptop and plugs to your USB port.
