How to repair tmp jpg files on pc?
Hi All,
Every time I try to convert a file on Mplayer it just fails and an error occurs “could not copy files/tmp/screenshots/3/000000001.jpg”.
Please help me how to repair tmp jpg files?
Hi All,
I am not sure will it work or not but you can give a try.
I suggest you to get a copy of a particular software which is actually free called IRFANVIEW.
You can convert any .bmp, jpg file stored in picture format (bmp, jpg) and deleted letter.
Hello Mike,
You can also use PixRecovery software as an alternative and repeat the steps to restore your files.
Dear Mike Pincher,
Thanks for your question.
Well there are 2ways to solve this problem.
1. First rename the image file keeping the JPG format.Press enter,.sometimes it may fix the problem.well if it doesn't then try the 2nd step.
2. You can use a software to fix the JPG files.there are many software for fixing the JPG files lyk- Pix Recovery,JPEG Recovery Pro Editor .You can download them from any site.
Just install them and follow the on-screen prompts and find the corrupted files and fix them. Save them in a permanent destination.
Hope this will fix your problem.
Best regards,
Zac.
