How to repair txt documents on Windows XP
Hello Experts,
Recently my Windows XP PC get crashed and my few very important text files got corrupted. It is very important for me to repair txt documents. Please provide me some way or software to repair My text documents.
Best Answer by Matthew J Moore
Answered By 35 points N/A #166270
Hi there,
You can surely recover your corrupted doc files using Stellar Phoenix Word Recovery. It has many advanced features like user friendly GUI, raw recovery, advance repair and so on. You can download it here- https://www.stellarinfo.com/repair-word-file.php
You can also check out EASEUS Data Recovery which specially in recovering text files. You can download it here- http://www.easeus.com/data-recovery/office-recovery-software/freeware-recover-text.htm
Hope this helped.
Answered By 45 points N/A #166271
Hello
There's another way to recover your document just within your system using Word's text converter. Open Word and click file then open. When the open box appears click the word document dialog. After this, choose the Recover Text From Any File from the Files of the drop down list. From this convert ASCII or your text document to any form and you will lose your word formatting and non text items such as pictures or any graphics but you should be able to extract most of the text information from that file. This method is only limited to word version 97-2003.
If this method doesn't work or if you don't like using this then i have this links for your document recovery. Click each link and download;
1. http://www.officerecovery.com/mediaheal/
2. https://www.wordrepairtoolbox.com
This one here is an online document recovery:
https://online.officerecovery.com/word/
Respond if this doesn't work. If it does then i hope it will help you.
