How To Replace And Remove The HP Proliant DL360 G5 Hard Drive
Hi. I am not very familiar with the computer-related stuff. What are the steps to replace and remove the HP ProLiant DL360 G5 hard drive? Please reply ASAP. Thanks in advance.
Hi. The steps to remove the hard drive require you to release the handle by pressing the latch of the ejector. Next, get hold of the handle and slide the drive from the server as a result of which the drive will get removed.
The steps to be followed for replacing the hard drive include sliding the drive into the slot until and unless a connection gets established with the backplane. Next, ensure that the handle fits in place by pressing it under the latch of the ejector.
Hope we helped.
