How To Replace Battery In Dell Laptop?
I want to replace the dead battery from the Dell laptop in order for my laptop to function properly. Can you please provide me with the steps to remove and how to replace battery in Dell laptop with a new one?
To replace the Dell laptop battery, you need to follow the steps
Step 1: Check your laptop brand and serial number to refer to the peculiar battery you need to buy.
Step 2: Remove the old battery by unlocking the battery locks. Battery locks would be like a switch which can be opened and closed.
Step 3: Use a cotton cloth to clean the interior of the laptop so that there is no dust left over.
Step 4: place the battery at the place and slowly push it in the case until a click sound is heard.
