g.k.sumon
250 points
Posted on - 09/10/2016
Hi. I am not very comfortable with computer which is why I don’t really know where to place what and how to troubleshoot hardware-related issues. How can the HP Deskjet 5650 colour inkjet printer be replaced? Please reply ASAP. Thanks in advance.
Nabeela
150 points
How To Replace HP Deskjet 5650 Colour Inkjet Printer In Simple Steps
Hi. The steps to replace HP Deskjet 5650 colour inkjet printer require you to first turn the printer on by pressing the power button. Next, you are required to put A4 sized white sheets in the tray after which the printer cover needs to be opened. Open the print cartridge by lifting it and then slide the cartridge out of the cradle. Next, the cartridge needs to be removed from the package and then the tape should be removed using a pull tab.
After this, slide the cartridge into the cradle and install the black or photo print cartridge in the print cartridge cradle on its right side. Until and unless the latch of the cartridge is not closed, keep pushing it down and finally close the cover of the printer. Hope we helped.
