How To Replace Ink Cartridge Of My Brother Printer?
I want to replace the ink cartridge of my brother printer and also make a test print of the page check whether the new cartridge is working properly. How to replace ink cartridge?
To replace an ink cartridge of your brother printer and to test the printing of that cartridge follow the given steps.
Step 1: Turn on the power if the printer and open the printer tray
Step 2: Press the base of the cartridge in the forward direction and move it a little in the front direction.
Step 3: Pull the cartridge in the upward direction and place the new cartridge in the tray.
Step 4: If the printer is connected to the system you will get a test print dialog box.
Step 5: Click on test print now button.
