jamesNick
Posted on - 08/06/2011
Hi good day could you please tell how to reset the Administrator Password without login in to the system, actually I forgot password for my user with Admin rights that I had created.
And I have no idea what password I'd used for default Administrator of the system So if u could help then please suggest I'm using Windows 7 Ultimate.
Is there any way.
How to reset the Administrator Password without login?
Hello first thing you have to do if you want to reset your password, or you may have forgotten it, then try the following steps:
When the systems starts and when you see the windows welcome screen / login, just press <crtl><alt><del> keys twice, then it will show classic login box, then type administrator without a quotes in the username just leave the password field in blank, then press Enter you should be able to login windows. So, now you can create and rest your account and password from the control panel > User accounts.
It’s the same thing can be done when using a Safe Mode Windows, it will show in this built administrator account in Login screen.
lee hung
75 points
Tips on Dell Windows 7 Password Recovery:
Option 1: Dell Windows 7 password reset by other accounts with admin rights
Option 2: Recover Dell Windows 7 password with command
Option 3: Create a bootable Dell Windows 7 password recovery disk
