How to Reset BIOS Password to Default?
Hello experts,
I have my BIOS password but I already forgotten it.
How can I reset it to the default password? Give me a step by step process on how to get this done.
Thank you.
Hello experts,
Thank you.
BIOS password protects your system from any outsider to access your operating system and your setup configurations, if you have set your bios password earlier and now you have forgotten this password and want to retriever please remember that this password cannot be retrieved but there is a process to unlock your bios and remove the password to set a new.
Please before you turn on your computer, unplug all of your cables and remove the outer case or your PC, then find your CMOS battery on your Motherboard, please remove it from your motherboard for a few minutes, after few minutes please again place it on its respective slot. Cover your PC and now plugged on all cables and turn on your computer.
Now your bios password is removed and can be reset by going to your setup configuration section.
Hi Mitchel, I will be more than glad to help you with that question; It is not easy to get the universal bios password but it is easy to replace it with a default one. Just do the following;
This should be able to solve your query.
I hope this solves.
HiÂ
Don’t worry there’s a lot of ways to reset, remove, and bypass the password. One of this is to remove CMOS battery and check out this Techyv link to get more tricks.
