Hello everyone,
I want to know how to reset chrome settings. I got too many pages saved and bookmarks in my chrome browser and I want to delete them at once so do you think resetting chrome settings to default will help me in this. If not please guide me to do it. Thanks in advance.
points
How to reset chrome settings?please help
Clearing Chrome’s settings and all other components means bringing the browser to the original state. There’s an option present in Chrome that will do the task.
1. Open a new tab, and go to “chrome://settings”.
2. Scroll down to bottom, click “Show advanced settings”.
3. Scroll down to bottom again, click “Reset browser settings”.
4. When the warning message appears, click “Reset”.
Your Chrome will be on the original defaults.
There’s also another way to make your Google Chrome fresh.
1. Uninstall Chrome. Make sure that removing all user data is checked.
2. Download and install the latest Chrome.
This will give you the cleanest browser with plain face.
In order to reset your chrome open the Google chrome browser, then there you see at the top right corner an icon with three horizontal lines click on it. A drop down box will appear, click on the settings. You will be moved to settings page. Next, scroll down the page and at the end of the page you will see a "show advanced settings" option. Click on it and there you will see a reset browser settings option, click on it and confirm the reset.
Your chrome settings are reset now.
