How to reset firefox 4?
I recently installed an add-on with my Firefox 4. Since then, Firefox 4 crashes. Sometimes, it would freeze. I am forced to use Chrome ( don't get me wrong. Chrome is nice. It's just that I'm a Firefox 4 fan :))
Hi Jciconte!
What add-on did you install? is it one of those search toolbars? Those really cause problems and stability concerning with browsers, and not just FF4. Have you tried uninstalling the add-on yet from control panel? You might want to do that first and then try to do a safe mode boot of FF4.
Here's how to boot into safe mode of FF4:
1. Launch FF4
2. Click on the FF button at the top left.
3. Go to help > restart with add-ons disabled
4. Click Ok
5. A window will appear with several options, in your case the best would be selecting: reset all user preferences to Firefox defaults + Restore default search engines
6. Finally, click on make changes and restart.
This should do it. If it doesn't, let me know!
Notifications
