How to reset or remember forgotten bios password?
I can not remember my bios password. So that I can not do any task in my computer. As a result I do not install operating system in my computer. What is the best solution about this kind of problem?
Hello Mickel,
It is very risky to set a password on BIOS. You must prefer to set the password on operating system so that you can reset it from the Administrator account or in serious case you can reinstall the windows. Well in case of BIOS. You must try to go to the BIOS settings to reset the password.
Otherwise there is a hardware piece which you have to unplug or replace to reset the password of BIOS. Open the box of your CPU and look for the round shape cell in motherboard. It is called BIOS chip. Remove it for about 1 minute and then set it again. And turn on your system you will see the password is removed automatically.
Hope this will be a good tip for you.
Setting BIOS password for a computer adds more security. You Set password to prevent others to access on your computer. But what if you forgot it?
Don’t worry there’s a lot of ways to reset, remove, and bypass the password.
One of this is to Remove CMOS battery.
Watch this video on how to remove, reset the BIOS password.
hope it can help you
You need to use a password of backdoor BIOS. Several BIOS producers execute a backdoor password. Backdoor password is known as a password that puts effort without considering whatever BIOS password has been fixed earlier by the user. Such passwords are generally utilized for protection and testing purpose.
It is common in nature that producers usually alter the backdoor BIOS passwords over times. 1. AMI Backdoor BIOS Passwords. Claimed AMI backdoor BIOS passwords involve; A.M.I., AAAMMMIII, AMI? SW, AMI_SW, BIOS, CONDO, HEWITT RAND, LKWPETER, MI and PASSWORD. 2. Recompense Backdoor BIOS Passwords.
A single claimed Award backdoor BIOS password implies as eight spaces. Other claimed recompense backdoor BIOS passwords involve; 01322222, 589589, 598598, ALFAROME, ALLY, ALLy, aLLY, aLLy, AWARD PW, AWARD SW, AWARD?SW, AWARD_PW and AWARD_SW. 3. Phoenix Backdoor BIOS Passwords. Claimed Phoenix BIOS Passwords involve; BIOS, CMOS, phoenix, and PHOENIX.
Hi
First of all turn on your computer, unplug all of your cables and remove the outer case or your PC, then find your CMOS battery on your Motherboard. To get more information visit this Techyv link : How to Reset BIOS Password to Default?
Notifications
