I bought a new laptop I was very happy, but it also has a problem what should I do, I don't understand why all machines having these problems if I prefer the new version, then why it has default I don't understand it my new Toshiba laptop is and it is having problem that I don’t know its restore settings please anyone can help me?
How to reset a toshiba laptop to factory settings
A Toshiba laptop has factory software which is hidden area on hard disc from this special hidden system image you can restore your information processing system
Following these steps:
1 shutdown PC
2 remove any hardware access like mouse keyboard
3 AC plugs and work make sure it
4 press 0 key while powering on PC release it when recovery warn show
5 recovery process offers OP select any one
6 warn screen appear
7 Click yes
8 Toshiba recovery wizard open recoveries of factory software and other option of your need
9 now cont. And follow direction
10 restart your PC
