nick nick
Posted on - 03/14/2013
Hi all techyv users,
I am finding some problem in Microsoft windows vista home basic, I have recently installed it. Earlier, I was using Windows 7 operating system, but now Microsoft windows vista home basic fixes some problem on my laptop.
An anyone educates me how to resolve problems in Microsoft windows vista home basic regarding display and configuration with other devices.
How to resolve Microsoft windows vista home basic fixes problem.
There are recommended minimum hardware requirements for Windows Vista Home Basic for its basic functionality.
Make sure you have these requirements, because without these, there will really be a problem with your laptop: (800-megahertz MHz 32-bit (x86) processor; 512 megabytes of system memory; DirectX 9-class graphics card; 32 MB of graphics memory; 20 GB hard disk that has 15 GB of free hard disk space; internal or external DVD drive; internet access capability; and audio input capability.
If you have a problem with your laptop after installing and shifting to a new operating system, first thing you need to do after installing Microsoft Windows is install the drivers for your laptop. When you buy a new laptop, it normally comes with a CD that contains the drivers. Insert that CD on your optical drive then install the drivers.
On the other hand, if you no longer have the CD, you can always download the drivers from the manufacturer’s website. Visit one of the following websites if your laptop came from one of these manufacturers and download the drivers:
On the support page, enter your laptop’s serial number or model number then click to search. When your product is located, click it to go to the download page. Select the driver download tab or section. The page should detect your operating system automatically. If a different operating system is displayed, click to change then select your correct operating system.
Download and install all available drivers and software for your laptop.
