How to resolve password issues in Win 7
Please note that anyone can use this disk to access your account on your computer, so it is important that you store the disk in a secure but accessible location!
Got that, I'll start creating one. How do we use it by the way?
Once you created the password reset disk, follow these steps:
1. At the Windows logon screen, click Reset password.
2. Insert the recovery diskette or USB key.
3. Follow the instructions on-screen to create a new password.
4. Log onto the account using your new password.
Do note that Password reset disks are valid for the account they were created on. If you use a password reset disk to recover your password, you do not need to create a new reset disk afterwards.
Hope this helps.
Pretty handy – thanks!
What will happen if I forgot my password and lost the password recovery disk? What are my options?
Unfortunately, if you forgot your password and lost your password reset disk, your only recourse is to reinstall your Operating System to retrieve the data before format is.
Add this Hard drive as secondary in a different machine and take the data backed up.So you have the data and the only thing legal is format. There are other software to manipulate but in this site we are strictly prohibited using illegal software.
