Hi all experts,
I have downloaded and installed successfully mcafee 4 on my laptop. But this version of antivirus is not removing/ destroying all viruses and spyware, my system processing speed getting worst day by day. Can anyone help me to increase processor speed with mcafee 4 antivirus or another tool to be install.
How to resolve problem with MCafee 4
Hi. Anthony ,
You have downloaded and installed successfully MacAfee 4 on your laptop. But this version of antivirus is not removing/ destroying all viruses and spyware, and your system processing speed getting worst day by day. So for this you can check some points..
1.     For all Spyware or Adware download a free anti-adware program like Spigot (S&D) or Adware. Adware is a easier and is recommended for in-experienced users. These programs will catch what the other miss so install both.
2.     Check to see if the problem is adware or your own program that are just lagging up your computer. Open the Task Manager [CTRL+ALT+DEL] and look at the process tab. Find any other processes that have an abnormally high Memory Usage. If you do not recognize their names, you have spyware; however, you should not try to disable them in the Task Manager.
Thanks & Regards
Gillam Janetj
